HELP MY T1 IDLE IN A4
Old Feb 13, 2003 | 08:20 PM
JaSSon's Avatar
Default HELP MY T1 IDLE IN A4
JUST PUT IN CAM AND LS6 INTAKE SURGES IN PARK AND WHEN COLD. ANY TRICKS OF THE TRADE WITH NO TUNING.
Old Feb 13, 2003 | 10:12 PM
98TAauto's Avatar
Default Re: HELP MY T1 IDLE IN A4
you can turn the set screw a turn to give it more air. You really need atap to read the IAC's when the car is warm to make sure they are in the 20-40 range. If not you may need to drill the TB hole larger to help with idle/surge. Raising the RPM helps idle, but you need EDIT for that.
