Z06 dyno'd, It needs tuning!
Old Feb 17, 2003 | 07:49 AM
minivette's Avatar
Default Z06 dyno'd, It needs tuning!
My GF had her 2001 Z06 dyno'd this past weekend. (it has 6k miles) It has a Blackwing and FLP's w/no cats. The A/F is weird. It starts lean, richens up, then gets too rich, leans out, leans out too much, then starts to richen back up. It did 361.3hp and 356.6tq
<img src="http://www.minivette.com/Z06/dyno1.jpg" alt=" - " />
LS1edit is in the near future. I'm thinking about 10hp more once I get the A/F ironed out.
Thoughts?
Full size dyno sheet
<small>[ February 17, 2003, 07:50 AM: Message edited by: Dr Debacle ]</small>
Old Feb 17, 2003 | 08:33 AM
Tim Sloper's Avatar
Default Re: Z06 dyno'd, It needs tuning!
There is definitely power there in the A/F (6-9) would be realistic). Did you happen to log timing and KR? If there is anything we can do for you let us know.
Tim
Old Feb 17, 2003 | 08:37 AM
minivette's Avatar
Yes, I did a data log with EFILive. There wasn't any KR at all. Initially, the timing dropped to 17ish deg then came back up to 22-25 deg the rest of the run. I can get the exact numbers this evening when I get home. Thanks for the input.
Old Feb 17, 2003 | 10:56 AM
Tim Sloper's Avatar
If you would like to forward me the EFI files I can take a look at them. I've got EFILive so I can view them natively. Correcting the A/F ratio would not be difficult at all. As for timing the car could most likely tolerate another degree or two in the upper end without any issues.
Tim
