throttle body questions
Old Feb 25, 2003 | 12:56 AM
OC BLACKZ28's Avatar
Default throttle body questions
Is it normal for my car not to idle on cold starts? It doesn't die, but surges from 450-650. If I give it alittle throttle, about 1000 rpm for 10 sec. or so, it will settle down at 750 till it warms up and then it's fine. Is this normal, and how can I fix it? I don't have a cam or anything, just intake and cat-back. Also, is it normal for the t.b to still have grooves in it from porting?
I appreciate any help, I am learning alot from you guys,
Thanks
Old Feb 25, 2003 | 12:58 AM
Default Re: throttle body questions
I forgot to tell you, my stock unit works fine, the idle probelm onl happens when I use the ported unit.
Thanks again
