P0410 Need some help with this....
how do i fix this problem? i checked to see if anything was disconnected and everything seems to be fine. is it true that you can get this code (P0410) fixed under warranty even though youre past the 3yrs/36k miles?(read it somewhere)
im just looking for some info on where to start checking or what to even look for that will cause this problem. also read somewhere on the internet that chevy has many problems with water getting into the air pumps and setting off the ses light with a P0410 code. is that true or did i misread it maybe?
thanks for any advice
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Ohhh, I'm very familiar with this code. One of my cars used to throw this one consistently.
P0410 is "Secondary A.I.R. Injection failure. This is an Emissions related device therefore the U.S. Government's rules supercede GM's warranty rules. Hence, this (or any emissions related device) is covered by a 5 year/50,000 mile Federal Mandate. Chances are though, it isn't the A.I.R. pump rather a slow heating O2 or low voltage reading from the O2's.
Here is the process;
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">DTC P0410 Secondary Air Injection (AIR) System
Circuit Description
An AIR pump is used on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Conditions for Running the DTC
-DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0300, P0325, P0327, P0335, P0441, P0502, P0503, and HO2S DTCs not set.
- The engine operating.
- The engine operates for greater than 15 seconds in short term fuel trim cells 2, 5, and 20.
- Engine speed is greater than 550 RPM.
- Maximum air flow is 22 g/s.
- ECT is greater than 50°C (122°F).
- IAT is greater than 10°C (50°F).
- Ignition voltage is greater than 11.6 volts.
- Engine load is less than 30%.
Conditions for Setting the DTC
- HO2S voltage does not go below 222 mV for 0.9 seconds when the AIR pump turns ON during closed loop operation.
- Short term fuel trim does not go above a predetermined amount when the AIR pump turns ON during closed loop operation.
Action Taken When the DTC Sets
- The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
- The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
- The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
- A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
- A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
- Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
- Using Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can aid in determining how many miles since the DTC set. The Fail Counter and Pass Counter can also aid determining how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This isolates when the DTC failed.
- For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2) If DTCs P0412 and P0418 are also set at the same time, this indicates the AIR pump fuse is open.
4) Excessive resistance in either the control circuit or the B+ circuit will cause an inoperative relay. Command each relay ON and OFF as necessary to verify operation. This step verifies the AIR pump operation.
9) This step isolates if the condition is the AIR integral stop valve or the AIR Bleed Valve solenoid. If no air is present at the outlet of the pump, this indicates a condition with the integral stop valve or circuit.
20) When an engine is started, a vacuum is created in the AIR system. This vacuum causes the integral stop valve from not opening which causes DTC P0410 to set. When the engine is started the PCM commands the AIR Bleed Valve solenoid to open and relieve the vacuum in the AIR system. This step verifies the solenoid is capable of relieving the vacuum.
DTC P0410 - Secondary Air Injection (AIR) System
Step 1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Yes: Go to Step 2
No: Go to Powertrain On Board Diagnostic (OBD) System Check
Step 2
Are both DTCs P0412 AND P0418 also set?
Yes: Go to Step 13
No: Go to Step 3
Step 3
Is DTC P0412 or P0418 set?
Yes: Go to Applicable DTC table
No: Go to Step 4
Step 4
Important
Listen for an audible click as the relays operate. If no audible click can be heard, inspect the related circuits for excessive resistance.
1) Turn ON the ignition leaving the engine OFF.
2) Enable the AIR System using a scan tool.
Does the AIR pump turn ON?
Yes: Go to Step 8
No: Go to Step 5
Step 5
Important
Refer to Electrical Center Identification Views for relay terminal identification.
1) n OFF the ignition.
2) connect the AIR pump relay.
3) n ON the ignition leaving the engine OFF.
4) be the AIR pump relay B+ supply circuit terminal at the underhood electrical center 1 using the test lamp J 34142-B connected to battery ground. Refer to Probing Electrical Connectors in Wiring Systems.
Is the test lamp illuminated?
Yes:to Step 6
No: to Step 21
Step 6
1) Turn OFF the ignition.
2) Reconnect the AIR pump relay.
3) Turn ON the ignition leaving the engine OFF.
4) Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
5) Disconnect the electrical connector from the AIR pump.
6) Probe terminal A of the AIR pump electrical connector to battery ground using the test lamp J 34142-B . Refer to Probing Electrical Connectors and Troubleshooting with a Test Lamp in Wiring Systems.
7) Enable the AIR System using a scan tool.
Yes: Go to Step 7
No: Go to Step 22
Step 7
1) Probe terminal A of AIR pump electrical connector to terminal C of the AIR pump electrical connector using the test lamp J 34142-B . Refer to Probing Electrical Connectors in Wiring Systems.
Yes: Go to Step 32
No: Go to Step 23
Step 8
Important
2) Disconnect the AIR Solenoid relay.
4) Probe the AIR solenoid relay B+ supply circuit terminal (switch side of relay) at the underhood electrical center 1 using the test lamp J 34142-B connected to battery ground. Refer to Probing Electrical Connectors in Wiring Systems.
Yes: Go to Step 9
No: Go to Step 21
Step 9
2) Reconnect the AIR solenoid relay.
3) Turn ON the ignition.
5) Disconnect the AIR pump outlet hose.
6) Enable the AIR System using a scan tool.
Is air present at the AIR pump outlet?
Yes: Go to Step 12
No: Go to Step 10
Step 10
1) Disconnect the electrical connector from the AIR pump.
2) Probe terminal B of the AIR pump electrical connector to battery ground using the test lamp J 34142-B . Refer to Probing Electrical Connectors in Wiring Systems.
3) Enable the AIR System using a scan tool.
Yes: Go to Step 32
No: Go to Step 11
Step 11
1) Test the continuity between the AIR pump and the AIR solenoid relay using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
2) Repair the circuit as necessary. Refer to Wiring Repairs .
Did you find and correct the condition?
Yes: Go to Step 37
No: Go to Step 31
Step 12
1) Inspect for a restriction/blockage or a disconnect in the AIR hoses/pipes between the AIR pump and the point where the system branches to both sides of the engine.
2) If you find a condition repair as necessary.
Yes: Go to Step 37
No: Go to Step 18
Step 13
2) Disconnect the AIR pump relay and AIR solenoid relay.
3) Probe one of the B+ supply circuits for the AIR Pump relay at the underhood electrical center 1 with the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors and Testing for Short to Ground in Wiring Systems.
Does the test lamp illuminate?
Yes: Go to Step 25
No: Go to Step 14
Step 14
1) Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2) Disconnect the AIR Pump electrical connector.
3) Probe terminal A of the AIR Pump harness connector with the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors and Testing for Short to Ground in Wiring Systems.
Yes: Go to Step 26
No: Go to Step 15
Step 15
1) Disconnect the AIR Bleed Valve solenoid electrical connector.
2) Probe terminal A of the AIR Bleed Valve solenoid harness connector with the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors and Testing for Short to Ground in Wiring Systems.
Yes: Go to Step 27
No: Go to Step 16
Step 16
Measure the resistance of the AIR Bleed Valve solenoid. Refer to Testing for Continuity in Wiring Systems.
Is the resistance less than the specified value?
Specified Value = 15ohms
Yes: Go to Step 29
No: Go to Step 17
Step 17
1) Install all the disconnected components.
2) Install a new fuse.
4) Enable the AIR System using a scan tool.
Does the fuse open?
Yes: Go to Step 33
No: Go to Diagnostic Aids
Step 18
1) Disconnect the AIR Bleed Valve Solenoid.
2) Probe the AIR Bleed Valve Solenoid B+ supply circuit terminal at the solenoid harness connector using the test lamp J 34142-B connected to ground. Refer to Probing Electrical Connectors in Wiring Systems.
3) Enable the AIR Solenoid relay using a scan tool.
Yes: Go to Step 19
No: Go to Step 24
Step 19
1) Connect the test lamp J 34142-B across the AIR Bleed Valve solenoid harness connector. Refer to Probing Electrical Connectors in Wiring Systems.
2) Enable the AIR Solenoid relay using a scan tool.
Yes: Go to Step 20
No: Go to Step 35
Step 20
1) Disconnect the vacuum line at AIR Bleed Valve solenoid.
2) Connect the hand vacuum pump J 23738-A to the AIR Bleed Valve solenoid.
3) Apply the specified amount of vacuum to the solenoid.
4) Enable the AIR Solenoid relay using a scan tool.
Does the vacuum hold before the solenoid was enabled and release when the solenoid is enabled?
Specified Value = 10 in.
Yes: Go to Step 36
No: Go to Step 28
Step 21
Repair the open circuit between the fuse and the relay. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Yes: Go to Step 37
Step 22
1) Test the continuity between the AIR pump and the AIR pump relay using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
Yes: Go to Step 37
No: Go to Step 30
Step 23
Repair the faulty ground connection or open AIR pump ground circuit. Refer to Wiring Repairs in Wiring Systems.
Yes: Go to Step 37
Step 24
Test the continuity between the AIR Solenoid relay and the AIR Bleed Valve Solenoid using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
Does the DMM display OL?
Yes: Go to Step 34
No: Go to Step 31
Step 25
Repair the short to ground in the ignition feed circuit between the fuse and the relays. Refer to Wiring Repairs .
Yes: Go to Step 37
Step 26
Repair the short to ground in the circuit between the AIR Pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Yes: Go to Step 37
Step 27
Repair the short to ground in the circuit between the AIR Solenoid relay and the AIR Bleed Valve Solenoid/AIR pump. Refer to Wiring Repairs in Wiring Systems.
Yes: Go to Step 37
Step 28
1) Inspect for a poor connection at the AIR Bleed Valve solenoid. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
2) If you find a poor connection repair as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Did you find and repair the condition?
Yes: Go to Step 37
No: Go to Step 29
Step 29
Replace the AIR Bleed Valve Solenoid. Refer to Secondary AIR Injection Bleed Valve Solenoid Replacement .
Yes: Go to Step 37
Step 30
Replace the AIR pump relay. Refer to Secondary Air Injection Pump Relay Replacement .
Yes: Go to Step 37
Step 31
Replace the AIR solenoid relay. Refer to Secondary Air Injection Solenoid Relay Replacement .
Yes: Go to Step 37
Step 32
1) Inspect for a poor connection at the AIR pump. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
Yes: Go to Step 37
No: Go to Step 33
Step 33
Replace the AIR pump. Refer to Secondary AIR Injection Pump Replacement .
Yes: Go to Step 37
Step 34
Repair the open B+ supply circuit to the AIR Bleed Valve solenoid. Refer to Wiring Repairs in Wiring Systems.
Yes: Go to Step 37
Step 35
Repair the open ground circuit to the AIR Bleed Valve solenoid. Refer to Wiring Repairs in Wiring Systems.
Yes: Go to Step 37
Step 36
Repair the vacuum line to the AIR Bleed Valve solenoid for the following:
- Restrictions
- Kinked vacuum line
Yes: Go to Step 37
Step 37
1) Select the Diagnostic Trouble Codes (DTC) option and the Clear DTC Information option using the scan tool.
2) Idle the engine at the normal operating temperature.
3) Select the Specific DTC option under the Diagnostic Trouble Code (DTC) option using a scan tool.
4) Operate vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test passed?
Yes: Go to Step 38
No: Go to Step 2
Step 38
Select the Capture Info option and the Review Info option using the scan tool.
Are any DTCs displayed that you have not diagnosed?
Yes: Go to the applicable DTC table
No: System OK</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Circuit Description
Diagnostic Aids
Test Description
Step 1
Yes: Go to Step 2
Step 2
Yes: Go to Step 13
No: Go to Step 3
Step 3
No: Go to Step 4
Step 4
Important
Yes: Go to Step 8
No: Go to Step 5
Step 5
Important
Yes:to Step 6
No: to Step 21
Step 6
Yes: Go to Step 7
No: Go to Step 22
Step 7
Yes: Go to Step 32
No: Go to Step 23
Step 8
Important
Yes: Go to Step 9
No: Go to Step 21
Step 9
Yes: Go to Step 12
No: Go to Step 10
Step 10
Yes: Go to Step 32
No: Go to Step 11
Step 11
Yes: Go to Step 37
No: Go to Step 31
Step 12
Yes: Go to Step 37
No: Go to Step 18
Step 13
Yes: Go to Step 25
No: Go to Step 14
Step 14
Yes: Go to Step 26
No: Go to Step 15
Step 15
Yes: Go to Step 27
No: Go to Step 16
Step 16
Yes: Go to Step 29
No: Go to Step 17
Step 17
Does the fuse open?
Yes: Go to Step 33
Step 18
Yes: Go to Step 19
No: Go to Step 24
Step 19
Yes: Go to Step 20
No: Go to Step 35
Step 20
Yes: Go to Step 36
No: Go to Step 28
Step 21
Yes: Go to Step 37
Step 22
Yes: Go to Step 37
No: Go to Step 30
Step 23
Yes: Go to Step 37
Step 24
Yes: Go to Step 34
No: Go to Step 31
Step 25
Yes: Go to Step 37
Step 26
Yes: Go to Step 37
Step 27
Yes: Go to Step 37
Step 28
Yes: Go to Step 37
No: Go to Step 29
Step 29
Yes: Go to Step 37
Step 30
Yes: Go to Step 37
Step 31
Yes: Go to Step 37
Step 32
Yes: Go to Step 37
No: Go to Step 33
Step 33
Yes: Go to Step 37
Step 34
Yes: Go to Step 37
Step 35
Yes: Go to Step 37
Step 36
- Restrictions
Yes: Go to Step 37
Step 37
Yes: Go to Step 38
No: Go to Step 2
Step 38
Wow, what a lot of info. As I have seen, 410 typically comes up when the pump is unplugged (or bad fuse)or locked-up (due to water). You can tell if the pump is running by starting your car in the early morning when its cold outside after the car has sat all night. Then pop your hood and listen for the pump running from behind your driver side headlight. Yes, any emissions device is covered under federal warranty. Anywhere from 5-7-10 years depending on the device.
<small>[ February 25, 2003, 04:00 PM: Message edited by: 2000WhiteZ28 ]</small>
Wow,CMNTMXR57 thats some good info <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Since its under warranty still i guess ill take it to the dealer and tell them what code it is and see what BS they can come up with <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
thanks for the great info.
2000WhiteZ28,when i was looking at the hoses last week i had the engine running from a cold start and since i have the slp lid and have that hose on the side of it i disconnected it and it was sucking air in. then i heard a click and it no longer did suck in air. so im guessing it still works right. it may have water in it since thats what i mostly heard of off the internet.
thanks again for your replys really appreciate it.
Hey, that's right from the horse's mouth. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
It just looks like a lot in this form. When you copy it into Word, it isn't so overwhelming. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Like 2000 said, you should be able to hear the A.I.R. pump going on and off after first starting the car. If it's doing that, the pump itself is working.
The process varies slightly from GM car to GM car, but I found mine to be a slow heating B1S1 O2 sensor that was the genesis of the 0410 code (as well as a few others).
Heh.. I got this code after a swapping in LT's !cats.. The tubes are sitting in the engine bay blowing onto my fuel rail covers until I get tuned. Then i'm gonna !AIR b/s and throw it in the trash.
