using the HPP3
Old Feb 25, 2003 | 05:49 PM
topfueluhl's Avatar
Default using the HPP3
...should I change the Rev limiter, shift firmness, and shift points on my car?
car is in sig.
Thanks.
Old Feb 25, 2003 | 06:11 PM
Cal's Avatar
Cal
Default Re: using the HPP3
There's no need to change the rev limiter or shift points unless you install a big cam.
Old Feb 25, 2003 | 06:42 PM
minivette's Avatar
Definitely do not raise your rev limiter on a stock valve train.
Old Feb 25, 2003 | 07:48 PM
topfueluhl's Avatar
What about shift firmness?
There are 4 levels of increased firmness: 25%, 50%, 75% and 100%.
Old Mar 3, 2003 | 01:23 PM
scalemaster's Avatar
i also have a hppIII but I have all the exhaust
from header's y pipe high flow cat's cut out's
and also will like to know if I can do the same <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Mar 7, 2003 | 12:49 AM
Honez's Avatar
Your stock rev is set at 6200, I personally feel you can raise it to 6300 with no issues. I set my shift for 1-2@+3, 2-3@+6 and 4-3@+9, with shift firmness at 75%. You will quickly notice that the tranny is much better at those settings and you in town driving is much more fun. I also am one of the few LS1 owners that has the power mode installed and I don't ping and I really have noticed an increase in power. You can play from there but I would not adjust the rev any higher than what I stated unless you put in some firmer valve springs. For what I paid the HPP III has been worth the gains. I also run a 160 stat and have the fans set accordingly. My motor runs nice and cool, even in traffic and I really like the responsivness I have gained. I hope this helps you guys. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 7, 2003 | 02:01 AM
nuzee's Avatar
I got about .1 to .15 improvement in ET & little over 1 mph more with the 1-2 & 2-3 both set at +2. I have a 2002 2.73 w/lid & cutout. I got another .1 improvement w/power tune & near 1 mph gain.
From what I've noticed, certain years, like 99s especially do not take well to the power tuning. I don't know if that is true, just something I've noticed.
I set my shift firmness to 100%. I would set it to 200% if it would let me <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> It seems the 2002 has some aggressive torque management programming which kind of dampens hard shifts. So 100% may not be a preferable setting for yours.
Hope this helps.
