P0405 Code after LS6 Intake install
When I installed the intake I simply removed the EGR system and installed a block off plate onto my headers. Is thier something else I need to do with the wiring harness since the EGR connector is not connected to anything now or should I call MTI and ask them about the computer programming? I do not think the SES light is hurting anything except my car will not pass emmissions with it on.
Thanks,
Darren
For now, what you could do is just plug whatever valve/sensor/thing (sorry....have an 01 so don't have EGR...) was on that harness back in and just zip tie it somewhere out of sight and see if that clears the code till MTI tells you what is wrong. I did this when I removed my AIR and EVAP systems but did not own LS1Edit yet.
Chris
Thanks for the reply.
Thanks
Darren
Have you thought about getting it tuned localy? You stand to get a better tune because the tunner can make adjustments that are specific to YOUR car. When you send off, its still a somewhat "generic" tune.
Chris
