Oh my God
Old Mar 1, 2003 | 12:56 AM
rphinney's Avatar
Default Oh my God
Well IM in the market for a trans am, and I want to install ls1edit auto tap or efi live on the new car, but well basically im confused as hell can you guys give this lowly retard some help here an explanation on what each of these is/does also how do I hook up a cable to my computer.and what is the best way to maximize boltons and NOS that is what I plan to install? lastly using the system of choice (let me know what one you think is best) how much HP and torque could be gained? Thanx so much!
Old Mar 1, 2003 | 02:16 AM
rphinney's Avatar
Default Re: Oh my God
anyone?
Old Mar 1, 2003 | 02:16 PM
2K T/A Driver's Avatar
LS1edit is the best. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
EFILive is what I have and is a good scanner.. as is autotap, you need to pick which one you want.. they both do essentially the same thing.. go to www.autotap.com and download the demo's and pick the interface you like best.. that's sorta what I did..
LS1Edit is a just that.. and ls1 edit program.. it can do anything you want to do.. including destroy your engine if your not careful.. it can manipulate your pcm to do what you tell it..
All of these plug into a port underneath the steering wheel via a cable which runs into a port on a laptop..
Ohh yeh, and just a friendly word of advice, on these boards "NOS" is refered to as "N2 or Nitrous" so as long as you call it that, you';; be ok.. you say "NOS" and you'll get messed with.. Nawwwwwwsssssss... ricer.. spoon engines.. etc.. I personally think it's gone too far, but just a word of warning.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 1, 2003 | 03:49 PM
rphinney's Avatar
so what does the scanner tell you?
Does it just pull trouble codes, will the ls1edit work all by itself ?
Old Mar 1, 2003 | 04:12 PM
Doc99SShome's Avatar
You need a laptop. It sounded like you think that LS1Edit and AutoTap are loaded on to the car. They are not. You load these two programs on to the laptop and you connect the laptop to the car diagnostic plug by use of a special cable. Each program comes with its unique cable.
Old Mar 1, 2003 | 05:40 PM
rphinney's Avatar
so ls1 edit does not take readings off the car and that is what the autotap is for?
Old Mar 6, 2003 | 11:04 AM
Cal's Avatar
Cal
LS1edit is for modifying tables in the PCM, AutoTap is for taking the readings off the car. So you really need both of them.
