Edit and MA tuning
Old Mar 4, 2003 | 09:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Edit and MA tuning
To tune in your MAFT settings do you just change the MAF table in edit?
I wan't to transfer my 5% rich setting,then start tuning in the rev range L-terms.
Thanks
Old Mar 4, 2003 | 08:42 PM
NoGo's Avatar
Default Re: Edit and MA tuning
It depends where you made the adjustments on the MAFT.
If you made the adjustment to the BASE setting, then you will want to shift your entire MAF table the exact amount that your dialed in your MAFT to
Example: 5% BASE richening on the MAFT = Multiply the MAF table by 105%
5% BASE Lean on the MAFT = multiply the MAF table by 95%
If you made the adjustment to the WOT setting, then you will want to shift your MAF table at all frequencies above 8000 hz
Example: 5% WOT rich on the MAFT = multiply all points on the MAF table above 8000 hz by 105%.
Good Luck,
Kevin
Old Mar 4, 2003 | 10:03 PM
Tim Sloper's Avatar
5% adjustment on the MAFT is not the same as adjusting the MAF table by 5%. The difference at higher flow rates between the MAFT and MAF table for the same % is very significant. See below...
<img src="http://www.cs-performance.net/Images/maf.gif" alt=" - " />
Tim
Old Mar 4, 2003 | 10:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thanks for the responses.I think I'm getting the hang of this Edit thing <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
