thoughts on A/F/R tuning
Old Mar 5, 2003 | 11:18 AM
spanktu's Avatar
Default thoughts on A/F/R tuning
Most people have been using the MAF transfer function for tuning no/low load ltft's and PE-RPM
scale for WOT , has nobody thought about just using the injector offset table for the whole
power range????
Just a thought I wanted to bounce off the experienced here
Old Mar 7, 2003 | 09:58 AM
spanktu's Avatar
Default Re: thoughts on A/F/R tuning
just an update:
not that anyone cares but......
I have had more success tuning with the injector offset table than with the maf table.
Using the same % scaling technique,seems to produce more accurate results.
AGAIN this is for a over-all fuel adjustment
you will still need to tweak your PE table for
WOT fine tuning.
Just wanted to follow up
Old Mar 10, 2003 | 12:52 AM
lbz34's Avatar
Thanks, I have been wondering where to tune for partthrottle/cruise A/F's. Didnt like the idea of using the maf tables. Loks like there is an option. May take both tables to get dead on.
Old Mar 10, 2003 | 01:18 PM
spanktu's Avatar
when I adjusted the table
I had no major deviation from Idle to full throttle
bank1 stayed around -2 and
bank2 stayed around -1
through the whole powerband
now my ltft's before were very steady
at 4 to 5
but yes I did not like the idea of "fooling" the computer with the maf table
It seemed more logical to mess with actual injector time.
Old Mar 10, 2003 | 03:20 PM
TaTommyWS6's Avatar
I also used the Injector table and it works great. I scaled it down 93% and my LTFT are right a -1
I then adjusted PE VS RPM for WOT adjustment.
What a difference!
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 11, 2003 | 09:38 AM
spanktu's Avatar
you are talking about the IFR table
I am talking about the injector offset table
either way should be the same end result
