MAP Sensor question
Old Feb 23, 2006 | 04:34 PM
02WS6Bird's Avatar
Default MAP Sensor question
PCM threw a code for both aspects of the MAP sensor it seems. The Sensor "guage" on the HP tuners was not registerring more than 20. No more no less only @ 20. Double checked the wires they are fine w/ a good connection, would this likely be the sensor itself?
Old Feb 23, 2006 | 05:01 PM
horist's Avatar
check all the fuses first, specifically the engine sensor fuse.
However if it set this out of the blue, and clearing the codes still yields a 20kpa MAP reading, then likely is the MAP sensor... they're easy to replace, see if you can borrow one from someone just to test
Old Feb 23, 2006 | 10:14 PM
02WS6Bird's Avatar
Thanks i replaced the sensor, so hopefully this will do it, if not back to chekcing the wires
