tunning problem
well, fast forward, i plug my maf in, and i throw codes 0131 0151 (front 02 sensors). this codes are only when i floor it and it goes over 60+mph and about 4500Krpms or higher, in other words, when i race....
anyways, i emailed him and he said that i am supposed to leave the maf connected something about dual tune or something thru efilive? unless i misunderstood him. anyways, i got a new maf, and i put it on, and plugged it in, and still the same codes....
what i dont undertand, why does it throw the front 02 sensor codes when i PLUG the maf, but not when i leave it UNPLUGGED.?? shouldt it throw the 02 code all the time, regardless if the maf is connected or not??
please guys, i need your help, im really at wits ends, i ran a 12.5 and put on rear adj shocks, drop springs, and some skinnies in the front and i went to a 13.0, and everyone tells me cus of the SD tune
please!!! all help is apprecited!! Temps will affect your times anyway with or without the maf. Intake temps are used for SD too. Just look at the corrections dyno's do for IAT variances.
Id leave it unplugged, even replace with a piece of straight pipe, you should then find even more power.
anyways, so why does my ses light only come on when my maf is plugged in and i throw both 02 front sensor codes? and with it unplugged i throw no codes?
