Question for tuning experts out there
I have just installed a Granetteli 85mm MAF. I already had the HPPIII Power Tuning in. There was no resulting detonation for the first several weeks.
Then I got a bad tank of gas and it detonated. I took out the power tuning and ran several tanks through it. I just reinstalled the Power Tuning and filled up at my favorite station. No detonation.
My question is - with what I am doing can I lean the car out too much and cause damage without knowing it? Another words, if I don't hear detonation, no codes are coming in, and the car is pulling harder than ever, can I assume it is good?
I know that I really need to get it ATAP'd or someting to know what is up, but on my limited budget, I can't do that every time I turn around and can't afford my own copy.
I just wondered if the system can compensate for dummies like me or should I stop fooling with it?
The best way to check would be to pull a few plugs and take a look at the condition of the electrode(s). They'd be the first thing to melt, break off, deteriorate under major detonation before punching a hole through the top of any pistons. If you pull them out and they look like they should normally, I wouldn't lose much sleep.
I think you're fine.
I'm thinking of getting a Scanmaster to see what it is up to. And then maybe a MAFT to richen it up if need be.
