The low coolant light
Old Mar 11, 2003 | 11:38 PM
finalymodded's Avatar
Default The low coolant light
What would cause the coolant light to stay on even when the radiator, and reservoir is full.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 12, 2003 | 08:42 AM
Camaroholic's Avatar
Default Re: The low coolant light
Bad coolant level sensor in the radiator. Been there, done that. Even if it's not gunked over, it can go bad.
Check the wiring first, tho. The sensor is on the passenger's side of the radiator, a little below the overflow tube line. Easiest way to change it is to pull the battery out and get it from the top.
-Andrew
