Timing?
Old Mar 13, 2003 | 11:35 AM
cgfirehawk's Avatar
Default Timing?
What is the max timing I could run on a N/A motor at WOT without any detonation. I am running all bolt-ons and S2 H/C with a 224/226, 568/571 @ 113.
Old Mar 13, 2003 | 02:14 PM
cgfirehawk's Avatar
Default Re: Timing?
ttt
Old Mar 14, 2003 | 08:19 PM
NoGo's Avatar
Default Re: Timing?
You should be able to run 31 to 32 degrees of timing with 93-94 octane gas.
Old Mar 14, 2003 | 11:16 PM
98TAauto's Avatar
Default Re: Timing?
28-32 but you will have to play with that yourself.. if you get pinging with 32, back off a few degrees. Every car reacts different <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 15, 2003 | 02:56 PM
cgfirehawk's Avatar
Default Re: Timing?
Thanks for all your suggestions guys!
Carl
Old Mar 15, 2003 | 10:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Timing?
Matters what year it is.98-00 should be good around 30.If it's a 01 or 02 I would suggest copying a 98 timing map.There is as much as a 10 degree difference in the midrange.
Old Mar 16, 2003 | 02:01 AM
Turk01SS's Avatar
Default Re: Timing?
MTI tuned mine with 30 at 6200rpm. I run about 28-29 in the 5000's. No knock
