LS1 edit question
Old Mar 15, 2003 | 03:35 PM
30thta436's Avatar
Default LS1 edit question
I just got edit and I'm having problems.
I can read the pcm. Then I open the edit program.
It brings up the file. But the edit option at the top is not highlighted. I can't click on it.
At first I thought it was because the pcm had ed wright tunning in it. So I put another pcm in and programmed it with stock programming. I read the pcm and am still having the same problem.
Any help would be appreciated.
Old Mar 15, 2003 | 08:17 PM
30thta436's Avatar
Default Re: LS1 edit question
I used another license on a friends 98 corvette. It worked fine. I don't under staned why it won't work on the 99 TA with stock or ed wright pcm.
Old Mar 15, 2003 | 09:04 PM
Camaroholic's Avatar
Have you emailed Ken (pcmdoc@surfree.com) about this?
Sometimes mistakes are made when they build the LS1Edit distribution. You may not have the correct files from Ken.
HTH,
Andrew
Old Mar 15, 2003 | 10:48 PM
30thta436's Avatar
I did emial ken. He emailed me back.
I had an older version of LS1 edit on my laptop.
It was only for 98. When I installed the new software they sent me. I didn't over wright the old software.
Ken told me to uninstall and delete all the LS1 edit software on my laptop. Then reinstall the software they sent me.
I did that and it worked. So it was my error.
