rotating the mass air meter change the A/F?
Old Mar 15, 2003 | 08:30 PM
waverider's Avatar
Default rotating the mass air meter change the A/F?
Lets say if I rotate my SLP mass air clockwise so the plugin is on the left side instead of the top would it change the readings to the pcm?
Old Mar 15, 2003 | 08:32 PM
waverider's Avatar
Default Re: rotating the mass air meter change the A/F?
Opps I meant the plugin is on the right side.
Old Mar 16, 2003 | 01:10 AM
waverider's Avatar
I know on my mustangs that if you rotate the mass air sensor if changes the readings the pcm gets. Does this apply to a LS1 too? Anybody tried this before? I will try it tomorrow.
Old Mar 16, 2003 | 09:56 AM
MIGHTYMOUSE's Avatar
mustangs have a sampling tube so air comming around a corner before the maf could hit or miss the sampling tube if it was rotated one way or another. we dont have a sampling tube
