PCM codes without scanner tool
Old Mar 19, 2003 | 11:09 AM
67ls1CamaroProject's Avatar
Default PCM codes without scanner tool
Does the LS1 2000 PCM output the codes in any way without the use of a scanner tool. My 91 corvette used to send out a specific flash sequence to the check engine light. Like 2 flashes and then a delay then 4 flashes, would indicate a code 24.
Old Mar 19, 2003 | 04:28 PM
Camaroholic's Avatar
Default Re: PCM codes without scanner tool
No. The ability to flash codes died after the '93 LT1. All subsequent (1994+) F/Y cars require intelligent scan tools.
-Andrew
