Need Help!!!!
Old Mar 20, 2003 | 03:32 PM
Predator's Avatar
Default Re: Need Help!!!!
Either purchase LS1 Edit yourself: http://www.carputing.com, or find a shop with Edit that can do it for you. Also, there are tuners online here who would do it for a fee, if you don't mind mailing your pcm. Good luck!
Old Mar 21, 2003 | 12:47 AM
Jason1756's Avatar
Default Need Help!!!!
All,
Is there a way to permanently program/remove a specific DTC from ever triggering again? I am getting an intermittent code of P0234 (engine overboost condition). I have a code eraser, but it is really a bummer to have to pull over and erase this code each time it comes on. I could live with code itself if it didn't cut my boost levels 50% every time it tripped. I know I am running safe boost levels, with correct a/f ratios using 100 octane fuel. I just want to permanently get rid of this code from the PCM. Any ideas or suggestions will be greatly appreciated.
Thanks,
Jason S.
