Help with tune..
If you like lope go for it, else clear it off.
Also the less RPM the better for the engine. If you cam makes more power higher in the range you need to make a call.
More power and less engine life, or less power and more engine life.
6400 should be ok, after then you are accerating the wear which increases geometrically with engine speed.
