AutoTap questions
Old Mar 27, 2003 | 04:54 PM
Gold Phoenix's Avatar
Default AutoTap questions
I would like to know what is normal or not on my readings. Like my ignition timing was 41 degrees at WOT. And at low RPM and heavy loading, I had some KR. What is acceptable?
Old Mar 29, 2003 | 08:47 PM
JamRWS6's Avatar
Default Re: AutoTap questions
KR under 3 is generally Ok.....even a little over 3 is ok. 4 or higher and i would say you have some problems.
Old Mar 29, 2003 | 09:26 PM
jaywoo's Avatar
41 degrees of ignition timing is very high. Normal is around 28 degrees at WOT.
