Airbag SDM replacement
Old Mar 1, 2006 | 11:10 AM
Vetterookie's Avatar
Default Airbag SDM replacement
SDM was removed in error by previous owner ('98 vette). Can't locate fuse to SIR in order to disable. Would it be careless of me to disconnect battery, let car sit a while and assume there would be no power while replacing module, or can someone help me with locating fuse? I have a maintenance CD, but the diagram of fuse box isn't the same as mine. I don't have owner's manual yet.
Thanks..
Old Mar 1, 2006 | 09:00 PM
02RedHawk's Avatar
Airbags need a power source to deploy. If your battery is disconnected, the DAB/PAB will not deploy.
Old Mar 12, 2006 | 11:37 PM
swmn's Avatar
Not sure about the 98s. If you haven't done the job yet, the 2004 GTO comes with a an "accessory power source" inside the SDM. Sounds like a fair sized capacitor to me. Helm's for 04 goat says leave the fuse in, disconnect battery, and then wait 5 to 7 minutes before messing with the SDM.
HTH,
S
