LS1 edit
So anyway, I talked to Mike at Rapid motorsports (he's local) and he wants $450 plus I have to pay to rent the dyno.
I was wondering how difficult it would be for me to fine tune the car and do something for the idle if I bought the program.
How much is it, where can I get it?
THANX FOR ANY INPUT
<small>[ April 02, 2003, 08:25 AM: Message edited by: muscratmauler ]</small>
Do some searching in this forum on "idle", and you will get quite a few hits. Also search on IAC.
Also go over to http://www.ls1edit.com and search the archives there. And don't forget to hit the LS1Edit FAQ button at the top of this forum, and read ChrisB's page.
Hope this helps. If you're not happy with it, obviously they didn't do it right. I'd hope they'd take care of you...
-Andrew
what would the 920-940 come out to for air/fuel ratio?
thanx
For example, 920 mV on my car may be 12:1, 920 mV on your car may be 13:1. But 450 mV on both cars will be 14.7:1.
The only way to really know AFR is with a wideband O2 sensor reading. Ours are 'narrowband', only accurate within a small range.
HTH,
Andrew
