a/f ratio tuning based on load/gear
Old Mar 30, 2003 | 01:44 PM
parish8's Avatar
single digit dreamer
Default a/f ratio tuning based on load/gear
i have atap, ls1edit and fjo wideband. been dialing in my tune a little. here is my problem.
shooting for low 11/11.5-1 a/f ratio, when it is under the highest load it tends to be richer than other times, how do i adjust for this. here is what i am seeing.
floor it and when the stall is just grabbing(high load) i see 10.5-1, then once the rpms start to rise again(not as high load) i see ~11.3-1, then all the rest of 1st and 2nd i see ~11.3-1, then finialy when i hit 3rd(high load) it drops to 10.5-1 again till the end of the run.
is there a way to adjust for this with ls1edit? it is not rpm dependant so the PE/rpm section wont work for me.
Old Mar 30, 2003 | 11:23 PM
parish8's Avatar
Default Re: a/f ratio tuning based on load/gear
here is a screen shot, hope you can see it ok, after looking closer i think it may be rpm dependant, i am just not in the 4200-4800range very long except for 3rd gear. these are 1/8th mile runs, maybe some 1/4 mile runs would be geting lean at the end of 3rd.
<img src="http://members.***.net/parish8/aflog.jpg" alt=" - " />
<small>[ March 30, 2003, 11:34 PM: Message edited by: parish8 ]</small>
Old Apr 1, 2003 | 12:16 AM
red ws6 99's Avatar
Have you turned off COT (catalytic over temperature)? This will cause a dip in AFR.
Gary
Old Apr 1, 2003 | 11:16 AM
Phate's Avatar
You should try and do as much of your WOT tuning in a 1:1 gear as possible.
So, A4 guys should tune in 3rd and M6 guys should tune in 4th.
After you get the 1:1 AFR dialed in where you want it then go back and tune the lower RPM points to where you want them.
I also have the FJO WBo2 in my car and have used it extensively for tuning. It is a great little tool.
Scott
Old Apr 1, 2003 | 03:48 PM
parish8's Avatar
i do have the cot feature shut off. i will try and do some tuning in 3rd, that only makes sence to give it the most time to log but i have a slight problem, for me 6000rpm in 3rd gear is close to 140mph <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> .
Old Apr 1, 2003 | 05:34 PM
Phate's Avatar
I never said that it was easy...or safe <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Just find a nice empty freeway or long industrial street and go play at about 2:00am.
Scott
