how much timing for 8psi and 35shot?
Old Mar 30, 2003 | 02:10 PM
parish8's Avatar
single digit dreamer
Default how much timing for 8psi and 35shot?
how much timing on a 6.0 with 9.4-1 compresion, 8psi whipple and a 35shot, running 100octane, 11.5-1 a/f ratio or richer?
i am seeing 14deg with no KR, it s running strong but i am always looking for a little more. should i be happy with 14deg or am i being excessively safe?
Old Mar 30, 2003 | 06:10 PM
NoGo's Avatar
Default Re: how much timing for 8psi and 35shot?
You should be able to take your timing slightly higher in the upper RPM. Try advancing your timing up after 4800 rpm I would guess somewhere around 17. 14 degrees sounds like a good pumpgas tune, however, I think the 100 octane will give you a little bit more room. Keep your timing low for all RPM's below 4800.
As usually, keep an eye on your KR. Every engine is different.
Good Luck,
Kevin
