What is the purpose of Full Rewrite?
Old Mar 2, 2006 | 10:58 AM
99FormulaWs6's Avatar
Default What is the purpose of Full Rewrite?
I know both big companies have that option, but what is the purpose? Is there something that can't be covered in a basic flash?
Old Mar 2, 2006 | 11:15 AM
2xLS1's Avatar
It rewrites the operating system in addition to the calibration.
Old Mar 2, 2006 | 11:43 AM
wait4me's Avatar
IT also allows you to make a compatible computer into another. For example,
a 99 silverado Pcm into a 2002 z28.
The Biggest thing that we like is the Custom operating systems that are being made, so we can use a factory computer to run our big engine combos. That requires a full rewrite of the pcm.
HumpinSS's Avatar
also you can use itt o upgrade to later OS's and custom Operating ssytems
Old Mar 2, 2006 | 03:10 PM
I knew EFI used theres for the Custom OS's I just wasn't sure what else it could be used for.
Old Mar 2, 2006 | 07:20 PM
gameover's Avatar
keep in mind it can also be used to fry your PCM... hence, only use it when absolutely necessary as mentioned above.
Chris...
