Wierd PCM issue, looking for info
Old Apr 2, 2003 | 10:24 PM
Terry Burger's Avatar
Default Wierd PCM issue, looking for info
Anyone know what the tach hookup wire (pin 10) does? Trying to diagnose my shift light problem I disconnected it, any to my surprise the car seemed to run fine (including my tach). I'm just wondering what that pin normally runs.
Old Apr 3, 2003 | 09:46 AM
Colonel's Avatar
Default Re: Wierd PCM issue, looking for info
Moving to PCM... <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Apr 3, 2003 | 10:36 AM
Team ZR-1's Avatar
You need to splice into pin 10 off the red PCM connector, which is a white wire, and also make sure that the shift light is setup for a four cylinder ignition to operate properly.
Being the signal is low, setting to 8 cylinders will not trigger the light, thus the fix is to set it to 4.
The issue is that the "tach output" off the computer on the '98+ LS1 motor is the
same as that of a four cylinder ignition (2 pulses per crank rev).
Making this cylinder selection adjustment has made the light work, and no ill effects should be seen.
Old Apr 3, 2003 | 11:02 AM
Thanks for the reply! I guess I didn't make myself clear. The shift light was working fine for weeks then just died the other day. It lights up when I start the car but its RPM trigger is not working (like it gets no signal). So I started checking out the wires and put a multimeter to the PCM-10 wire where the shiftlight was connected, I got nothing. So for ***** and giggles I cut the wire, no ill effect. It's the right wire, it just stopped working. I'm wondering what else runs off that wire so I can verify my diagnosis (i.e. what should stop working if that wire is cut). My tach still works fine and the engine runs.. (shrug)
Old Apr 3, 2003 | 08:48 PM
Riptide's Avatar
The other end of the wire goes to the ABS module. What the ABS module needs a tach signal for I'll never know... maybe it's used as an input for the cars with traction control.
