tuning on th TREX CAM
Remember that this cam is a hugh compression bleeder.
Just try adding timing on the dyno until it stops making more power.
Then start leaning it out until it stops making more power. Now you will know where it make max power at, then you can modify it form there.
any suggestions and ideas what the degree should be at and a/f and anything else!
