maft translator question
Old Apr 4, 2003 | 04:53 PM
merctech's Avatar
Default maft translator question
I had superchips tune my car but their dyno was broke so I took it to norse motorsports and put it on the dyno and the motor was running too lean so mike put the translator on it and set it 8% rich to counter the leanness. My question is I took the superchips tuning off will that also reset the translator back to stock.
Old Apr 5, 2003 | 07:56 PM
JamRWS6's Avatar
Default Re: maft translator question
I don't really understand what the heck has happened to your car but the translator has internal switches inside that must be turned to change anything.
Old Apr 6, 2003 | 09:05 AM
merctech's Avatar
I was told by a tech that when I put my stock program back in my computer that the computer will recalibrate itself.
Old Apr 6, 2003 | 04:29 PM
WS6 GreeN's Avatar
If you had a different program, you might want to go get it redynoed to make sure your A/F is still OK. It would depend on what the aftermarket program changed to start with. How the hell did they tune your car w/o a dyno?
Old Apr 8, 2003 | 10:05 AM
Dave@Ramchargers's Avatar
if you go back to stock tuning then yes you cannot run the MAFT at the same settings. they will need to be different
