Tranfering MAFT WOT settings to Edit?
Old Apr 4, 2003 | 08:22 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Tranfering MAFT WOT settings to Edit?
Whats the easiest ond most effective way to transfer my MAFT WOT setting to the Edit file?
I'm trying to transfer a -6 MAFT setting.Should I go with leaning the MAF table from 8000mhz and up or fuel injector pulse width from 3000rpm and up?
Thanks
Old Apr 5, 2003 | 07:16 PM
Doc99SShome's Avatar
Default Re: Tranfering MAFT WOT settings to Edit?
I'm assuming that you have LS1Edit. Also, if you have ATAP, I would strongly recommend that you remove the MAFT and start tuning from scratch. Go out & ATAP the car on part throotle runs so you have info to tune the LTFTs below 0%,, work with the MAF table to do this. Then, make some WOT runs and work with the PE RPM table for WOT fueling & AFR.
To answer your question directly, I know that the MAFT adjusts the frequency output of the MAF sensor. The WOT switch (I believe) works from 8000Hz and above as you said. So a MAFT setting of -6 for WOT would be a leaner WOT AFR. Since the MAFT works on the MAF frequency, the corresponding table in the PCM would be the MAF table. But you want to maintain a smooth MAF table curve,, so from 8500Hz and above multiply all cells by 95.0% using LS1Edit. Then going right to left in the MAF table change the multiplier by 0.5%,, mutli 8375Hz cell by 95.5%,, 8250Hz cell by 96.0%,, 8125Kz cell by 96.5%, so on and so on, until you hit 100%, then you are done.
