Could a MAFT pass the sniffer?
Old Apr 6, 2003 | 08:02 PM
glitch77's Avatar
Default Could a MAFT pass the sniffer?
I dont care really either way, because the are no emessions check in OK, but someone might like to know.
Could you use the MAFT to lean your engine so much as to pass the sniffer? Or are their other problems with this? Would be an easy way to do, just turn the dial for the tests.
I dont really know that much about how the tests work, or what super-lean conditions would do for the tests.
I dont know much of anything really. LoL.
Old Apr 6, 2003 | 08:35 PM
kick_*ss's Avatar
Default Re: Could a MAFT pass the sniffer?
That would depend on if the people doing the test know what it is. I removed the lable and did not have the MAFT noticable and passed the NC tests.
Old Apr 6, 2003 | 10:51 PM
cueball's Avatar
you are from OK, where?
i am from Tulsa OK.
i built a module that plugs in place of the
O2 sensor like O2 sims you can buy, but my module you adjust the air/fuel ratio radings
via an a/f ratio gauge and a *** you turn
in your console,or where you put it
some one could probobly use this to pass
a NC test.
Old Apr 7, 2003 | 08:11 AM
glitch77's Avatar
Cyril, OK. Its a long haul from Tulsa. about an hour SW of OKC. Not a lot of f-body diehards down here. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
