Swapping from 98 ECM to 01-02 ECM help!
Old Mar 3, 2006 | 05:50 PM
ddnspider's Avatar
Default Swapping from 98 ECM to 01-02 ECM help!
Im in the process of swapping my motor,and im going boosted and i know the 99+ ECM's handle boost better.So i got an ECM from an 01-02 M6,but i was told a couple of the pins are different or there might be other stuff,etc.What all exactly has to be changed to get it to work properly??Thanks
Old Mar 3, 2006 | 08:43 PM
ddnspider's Avatar
ttt!!
Old Mar 4, 2006 | 07:06 PM
SMonty's Avatar
I'm not sure, but if you can swap all the sensors to 99+ ones I would think that should work fine.
Old Mar 4, 2006 | 07:26 PM
bmfcamaro's Avatar
there has been a lot of these threads try searching. or call speed inc.
Old Mar 4, 2006 | 11:47 PM
ddnspider's Avatar
yeah i tried searching but i didnt find anything useful....ttt to anyone that can help
Old Mar 4, 2006 | 11:54 PM
2xLS1's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/446390-ecm-schematics-needed-help.html
https://ls1tech.com/forums/pcm-diagnostics-tuning/425313-98-02-vcm-swap.html
