Paging NoGo, WTF?
Is there some sort of abuse mode when starting from a dead stop? I have no clue what went wrong? I went fown the track 3 times and all 3 times it did this.
Cruising down the highway on the way home I hammered it. It almost didn't spin the tires at only 45mph? I figured that the temp might have something to do with it but, with only a 30 deg. difference? I have crap to do all damn weekend and this is going to drive me crazy until Monday.
Did you change your MAP/IAT timing adjustment table to 0 for all points? On your truck it pulls a significant amount timing of for hotter air temperatures.
<small>[ April 11, 2003, 09:48 PM: Message edited by: NoGo ]</small>
Go to transmission -> A4 Shift Firmness -> Torque reduction and zero out the
table
Trans Cal -> A4 Shift Firmness -> Upshift Torque reduction - zero out the
values
Engine -> Ignition -> Max Torque. Set it to 600
Engine -> Ignition -> Torque Reduction. Zero it out
Another question I have for you is about the running rich at startup. If I jack with the Crank VE do you think that this will help? I can actually smell gas during the first 2 min. of warmup.
Man thanks for the help.
