Need help fast!! huge problem.
Old Apr 11, 2003 | 10:20 PM
badz2801's Avatar
Default Need help fast!! huge problem.
Hey everyone.
Well I started my car up with the GWP stage II kit on it and now I have a major problem.
I installed autotap on my laptop following the directions. I hooked the cable to the car and it read the information from the pcm. I then went to start the car and the car will no longer start. I just started it before using autotap so I know thats what did it. What happened? I try to crank it over and I get nothing except the sound of sparks. The crank does not even turn over now. You pay 300.00 for logging software and now the car wont fire up.
Sincerely
Badz2801
Old Apr 11, 2003 | 10:32 PM
speedy101's Avatar
Default Re: Need help fast!! huge problem.
if your crank doesnt spin then these ie no way for it to spark, ls1,s read spark off the crank sensor only, your problem sounds like you pass-lock security module needs to be reprogramed.
Old Apr 12, 2003 | 12:48 AM
badz2801's Avatar
nm I got it to work. Low volts on batt.
