Need advice on where to tap in for gauges
Old Apr 15, 2003 | 10:00 PM
fcar99's Avatar
Default Need advice on where to tap in for gauges
I am getting ready to install a couple of electric autometer gauges in my 99 T/A an oil pressure and a water temp. I am just needing to figure out where I need to pull the signal for them from and where the locations are. Thanks.
Old Apr 16, 2003 | 10:54 AM
AsianIce25's Avatar
Default Re: Need advice on where to tap in for gauges
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Here's to autometer! I also have a phantom oil pressure gauge, but the stock sender is behind the intake, so i figured it would be a crap load easier and a good thing to put dual oil filters and a cooler on, then just get a fitting and put the sender there. The coolant one im not so sure about, but you could put it anywhere theres water...
