Can you get the P0410 from...
Old Apr 20, 2003 | 06:49 PM
minivette's Avatar
Default Can you get the P0410 from...
Can you get the P0410 code from burnt check valves?
The car a 2001 Z06 had FLP's installed without any restrictor plates. It was driven this way for a a couple months. I then installed the restrictor plates but you can stil hear the ticking.
I've done the search and I see where it mostly would point to a faulty AIR pump. But I was wondering if burnt check valves may also throw that code. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 21, 2003 | 06:08 AM
CMNTMXR57's Avatar
Default Re: Can you get the P0410 from...
Absolutley! Anything that affects it from doing it's job will generate that code. I went and looked it up. Steps 14 through about 22 specifically deal with checking inlet and outlet hoses, as well as the check valves and solenoid valves.
Old Apr 21, 2003 | 07:14 AM
minivette's Avatar
Thanks a million CMNTMXR57. I'll go ahead and try switching those out before I bring it to the dealer. Thanks a bunch! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 21, 2003 | 10:27 AM
CMNTMXR57's Avatar
No problem, when I was in SI this morning, I was in a hurry, so I didn't post the whole process as it is a lengthy one. But like I said, pretty much 14-22 deal with said check valves.
