Questions about routing the MAFT inside the car
i would solder,and shrinktube the splices
so you dont run into problems,you are working
with wires that has MHZ signals that run threw
it so you want a good sealed connection
there is a hole with a big rubber gromet
in it on the pass. side firewall
under the pcm,easy to use and perfect for
the glovebox application.
good luck!
Brad
We actually sell extensions for the translators and i ran min with 6' extensions and it was fine.. it through the reading off some, so i just adjusted
