How Much Fuel!
Old Mar 9, 2006 | 05:21 PM
trucksleeper's Avatar
Default How Much Fuel!
I've scaled tables as much as a 160% and have seen little or no changes in AFR. Supercharged car with 12#'s, wideband, speed density. Car is still lean. Any ideas as to what is going on any help would be greatly appreciated.
Old Mar 9, 2006 | 05:40 PM
foff667's Avatar
LS1TECH Sponsor
post a bin/tun/hpt file...and what "tables" you've scaled there are several tables that affect fueling...are you running an fmu? are you running a 2 bar tune? are your injectors maxing out? Info is helpful
Old Mar 9, 2006 | 05:44 PM
white2001s10's Avatar
You probably have to do your tuning in the back-up VE table instead of the primary.
Old Mar 9, 2006 | 05:46 PM
No fmu, running sumped tank with aeoromotive 1000 inline pump, 42lb svt injectors, @70 psi fuel pressure. i am referring to the ve tables.
Old Mar 9, 2006 | 07:05 PM
RedHardSupra's Avatar
then you probably forgot to turn off MAF, or it failed to fail over
