How to reset a 95 sonoma SES light?
Old Mar 13, 2006 | 12:06 AM
strokedls1's Avatar
Default How to reset a 95 sonoma SES light?
Just like the title sayes. I tried disconnecting the battery and pulling the fuses for the ecm, but no dice. Any help is appreciated. Motor is a 4.3L v6 4x4 if that makes a difference.
Old Mar 13, 2006 | 02:53 AM
ninobrn99's Avatar
have u tried going to autozone or somewhere that has an obd 1 code scanner/deleter? that would be one of the easier ways i could think ok..
Old Mar 13, 2006 | 11:36 AM
strokedls1's Avatar
I haven't tried that because I thought that they did not do code reading deleting in california anymore. I will ask them when I go pick up a fuel filter today.
Old Mar 13, 2006 | 11:46 AM
carzman5678's Avatar
To clear any Diagnostic Trouble Code (DTC) from the memory, either to determine if the malfunction will occur again or because repair has been completed, power feed must be disconnected for at least thirty (30) seconds or Tech 1 clear DTC(s) option is used. when Tech 1 is used other memory items will not be lost and have to be reset.
Alldata.....
Old Mar 13, 2006 | 12:39 PM
strokedls1's Avatar
Thanks for the info. Will try to get the guys at autozone to clear it for me. Otherwise I will just unplug the computer for a couple minutes. I just changed the plugs and still need to change the fuel filter before going for a reset. I think the computer is coding because of a lean condition. Plugs were white with some pitting so it is having a lack of fuel. Going to swap fuel filter and put in a bottle of fuel injector cleaner to hopefully get it resolved.
Old Mar 20, 2006 | 03:06 PM
00SSLS1's Avatar
you probably cleared by now, but I have that scanner that I could delete it with
