cannot figure this out????????
Old Mar 13, 2006 | 11:22 AM
getlifted's Avatar
Bad Seller Alert
Default cannot figure this out????????
Mods are -f14 cam,pacesetter lt's,ls6 intake
Have had many h/c combo's but never had this problem till now.
Car sputters and backfires under load-(driving in fourth and nailing the gas)
Also when i go full throttle, as soon as it hits 4 grand it sputters and pops and loses power.
Mikey at rapid had it on the dyno for a tune and everytime it hit 4 grand it would do this. Mikey said the fuel was not the problem but check the ignition.
I have checked the plugs and put new wires on it but no dice.
The car is a 98 so i beleive you can switch the left and right coil packs???
Not throwing any codes.
I don't know where to go from here. Pretty stumped at this point.
Any help would be appreciated greatly????????????????
Old Mar 13, 2006 | 11:42 AM
Spenser309's Avatar
check your battery cables. Maybe, when you hit 4k they rock and short out somewhere.
Old Mar 13, 2006 | 02:20 PM
Rob's Avatar
Rob
Check for a bad ground. They can do all sorts of weird things.
Old Mar 13, 2006 | 08:41 PM
getlifted's Avatar
Bad Seller Alert
which ground??? I recently put this motor in the car in a rush so i might have switched one of the grounds or connected to the wrong part of the car????? Which one would cause this sort of thing??
