Quick autotap question
Old Mar 13, 2006 | 07:04 PM
REDGAR's Avatar
Default Quick autotap question
I autotapped two runs
when reading the auto tap logs, once rpm and mph criteria are met the file shows current gear moving up.
In addtion, however, rpm continue to move up.
This leads me to beleive that the tune calls for the shift but the car will take a second or so to actually execute it (rpms top then go down).
Is this right or is this indicative of a problem?
Thanks for the help
Old Mar 13, 2006 | 07:37 PM
2xLS1's Avatar
Yes it takes the mechanical parts in the transmission some time to complete the shift after it gets the signal to shift from the PCM.
Old Mar 13, 2006 | 07:56 PM
REDGAR's Avatar
What is reasonable? Does it depend on combo?
Is 200 reasonable? 400? 600?
