AeroForce Interceptor
Old Mar 19, 2006 | 01:14 PM
badaSS346's Avatar
Default AeroForce Interceptor
Anyone using the AeroForce Interceptor scan gauges. Everytime i plug mine in, my tack and gauge cluster stops working and my service vehicle soon light comes on. When i unplug it everything works.
Old Mar 19, 2006 | 01:26 PM
Runn's Avatar
I have the dual setup and it works great (except oil preassure)
Old Jan 7, 2007 | 12:02 AM
02silverZ2805's Avatar
same here i got the dual set up..but i did notice when i pluged the add a circuit into the fuse panel, my rpm and mph needle shoot up.but everything works fine..knock on wood
Old Jan 7, 2007 | 05:28 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You must have tapped the wrong wire for +12v. I had a problem with the first ones I bought, because I accidentally tapped into a PWM 12v, instead of a true ign +12v.
Old Mar 20, 2007 | 10:02 AM
Racer383's Avatar
I read somewhere that even with the dual setup, you can still only monitor 2 things at once. it that even correct?
Old Mar 20, 2007 | 10:07 AM
2002blackZ's Avatar
Each guage allows you to monitor two things at once. With the dual guage you can monitor 4 things.
They are really nice for checking and resetting codes as well.
