HPTuners Newbie.
Old Mar 30, 2006 | 11:27 AM
Ohio Bird of Prey's Avatar
Default HPTuners Newbie.
I've read that with a ported throttle body such as a 90mm or a NW's you want to modify values in the "Efective Airflow Area".
Why can I not find this? Please help the newbie out guys.
Big thanks.
Old Mar 30, 2006 | 12:21 PM
Runn's Avatar
Ttt....
Old Mar 30, 2006 | 02:12 PM
ttt
Please help
Old Mar 30, 2006 | 02:15 PM
ringram's Avatar
I think its an ETC only table, if you are cable, then forget it.
Old Mar 30, 2006 | 02:32 PM
gameover's Avatar
http://www.hptuners.com/help/vcm_edi...le_airflow.htm
"IAC Position vs. Effective Area"
The ported TB shouldn't really need this if the idle bypass is close to the stock dimensions. If your car is a electric throttle then this table does nothing and you should look at the "ETC Area Scalar" instead.
99% of idle issues are caused by incorrect setting of the idle RPM, base running airflow, ignition timing or mechanical issues (vac leaks, bad O2 sensors causing inconsistent fueling etc.)
Chris...
Old Mar 31, 2006 | 11:41 AM
Runn's Avatar
I have an BBK 80mm, Should i change anything?
