Tuning for vac mod tranny
Old Apr 5, 2006 | 01:32 PM
white1's Avatar
12 Second Truck Club
Default Tuning for vac mod tranny
I should be getting my new tranny by the end of the week, or first of next week. I went from the regular 4l60e to a built 4l65 with the vacuum mod. What changes, if any, need to be made to the tune? If the solenoids are no longer being used, the only electronics Ill be needing is the TCC lock up, right? Any help is mutch appreciated.
Thanks
Old Apr 5, 2006 | 02:01 PM
BAIN's Avatar
The line pressure will be controlled by the Vac mod. So it doesn't really matter what you put in the tune. Also shiftpoints will be the rpm you want it to shift in the tune. Not like before when mph and rpm had to meet to make a shift.
