Stall/bog - no downshift
Old Apr 6, 2006 | 05:42 PM
mzoomora's Avatar
14 Second Truck Club
Default Stall/bog - no downshift
I Just bought the car and it needed a tune due to a cam. I had it tuned and it was much better, but it has the weird bog when you punch it from 30 or so. It dosnt die out, but it accelerates really slow. It feels like it is in top gear with the converter locked and it should be downshifting but it doesnt. It was doing it from slow rolls and sometimes even from a dead stop. It would roll out hit about 10 mph then slow down. It did this even before the tune but was hard to notice then. The car threw a TPS code and we replaced that, but now it is throwing a code again. I am going to take it back tommorow and see what the current code is, just trying to get some insight as to what the other problem could be.
Old Apr 6, 2006 | 07:18 PM
joecar's Avatar
Possibility: broken TPS wire.
Old Apr 6, 2006 | 07:55 PM
white2001s10's Avatar
Someone probably turned off the downshift tables so they could dyno it.
It's a common thing to forget I think.
Old Apr 6, 2006 | 09:41 PM
SSpdDmon's Avatar
If it's got a stock stall and 3.23 gears, you could just be in the low end of 2nd gear. That's why some cams suggest using a bigger stall. Then again, I'd check with whoever tuned it and see if they forgot to reset something as mentioned above.
Old Apr 9, 2006 | 12:47 AM
mzoomora's Avatar
It did it again tonight, Left ok, then got about 100 ft out or so and boged/stalled. When I shifted manually it was fine. Ideas?
Old May 28, 2006 | 01:47 PM
mzoomora's Avatar
Okay. I did a log of a short run. The car is shifting directly into 4th and then back down after a few seconds. If anybody thinks they can help I have an EFIlive lo of the run I can send you. Email me at mzoomora@msn.com
Old May 28, 2006 | 11:02 PM
Jpr5690's Avatar
i had a similar issue after my h\c swap it went away when i tuned out my dtc's that i was throwin for map system issues i also lost tcs with my prob
in any case id just make sure your tune is good
