Why so lean at WOT?
Example(made up numbers): At 7000hz and WOT I was at 3500rpms and wideband says 14.0. So I then divided actual AFR by commanded AFR, 14.0/12.8= 109%. I then multiplied the 7000Hz cell by 109%. I ran this calc for each area and chaned each maf cell accordingly. Went back out and tested it out after driving for about half hour. This time WOT AFR was just about right on what I commanded.
I am so damn glad I finally figured it out without doing it the ghetto way by just changing the PE table. Did a nitrous run and actually got richer when activated, I may have to put in a slightly smaller fuel jet. I figured i would post this in case it may help someone else one day that has ls1 edit(almost nobody, lol). Thanks everyone for the help.
Not sure if its just my imagination, but the car now seems like it pulls a lot harder with the AFR on point.
I'm glad to see you resolved your problem and please don't take this question as any type of critisism, but I don't understand why changing the MAF table is more ghetto than changing the PE table? My thinking is that the MAF table has been previously calibrated for that specific MAF sensor meaning that it provides a given freq for a given air flow. Technically, the only time we would want to change that table is if we changed that relationship, what am I missing?
Ok, I'll have to start a different discussion, I must be misinterpreting the question, but I would have done it the "ghetto way".
