computer pulling fuel
Old Apr 8, 2006 | 09:44 PM
blackhawk J's Avatar
Default computer pulling fuel
I need some guidance. I had my car on the dyno a while ago with a Tech II conected to the computer. The dyno graph showed the car was detonating from 5000 rpms and up. The Tech II said it was pulling fuel. I changed out the two upstream O2 sensors (and one faulty downstream sensor a while back). I have also changed the plugs to new platinum II's and wires from MSD. It still appears to be happening. I was told to check the A.I.R. hose for leaks. Can the smog pump have something to do with it? Am I looking in the wrong places? Any help would be appreciated...
Thanks
Old Apr 8, 2006 | 11:42 PM
brad8266's Avatar
Switch to some copper plugs, our cars like them better. Whoever told you it is AIR is full of it. AIR system being inop will not make you detonate.
