fluctuating timing problem
Old Apr 10, 2006 | 09:27 AM
02sierraz71_5.3's Avatar
Default fluctuating timing problem
Anyone ever have a problem with timing spuradically jumping around causing surging?
I think he has a faulty tps even with the engine off and ignition on the tps will read between 7 and 15, something seems to be causing the TB to fluctuate changing map readings and consequently timing.
No se lights
Old Apr 10, 2006 | 09:30 AM
MeentSS02's Avatar
Kleeborp the Moderator™
This a cable drawn throttle body?
Burst knock would be the first thing I'd be looking at...
Old Apr 10, 2006 | 09:34 AM
Its drive by wire, I noticed the map readings will dip spuradically under wide open when it does it. Its like the throttle body isnt staying open all the way and the butterfly valve is fluttering, there is no KR.
It will do it under part throttle also.
This is on a boosted motor.
Old Apr 10, 2006 | 09:38 AM
MeentSS02's Avatar
KR and Burst KR are two different things...neither of both?
Old Apr 10, 2006 | 09:41 AM
I thought Burst kr will read as kr in the histogram and there isnt any
Old Apr 10, 2006 | 09:42 AM
MeentSS02's Avatar
Nope...it's triggered by too great a delta in airflow...different things.
Old Apr 10, 2006 | 09:58 AM
I raised his delta air to .50 do you think it could need more?
Old Apr 10, 2006 | 09:59 AM
MeentSS02's Avatar
I'd have to go check what I raised mine to...but I think that would work fine. Go try it and see...you'll know right away if it ain't working.
