TPS code / tps not reading in scanner
Old Apr 10, 2006 | 01:15 PM
Hocky's Avatar
Default TPS code / tps not reading in scanner
For some reason, I am throwing a TPS code and the scanner (HPT) is not reading anything from the sensor at all. The weird thing is that the sensor is working fine with ~.7v closed and ~4.4v WOT. That measures the same at the sensor and at the pin on the computer, so that eliminates the wiring as a potential problem as well.
Any ideas?
