ls1 camaro hyper tech tuner questions, please help!!!
I recently purchased a hypertech power programmer 3 for my 99z28 ls1 camaro. Its all stock right now except for taller tires which I have adjusted. I am looking to increase my 1/4 mile time any little bit.(song long as it does not risk damaging engine). Here are my questions:
Should I adjust my rev limter higher from 5,500?
How should I adjust my shift points(any one who has same car specs maybe you increased your 1/4 mile time?)
What percentage should I set my shift firmness to?
Lastly any one know what gears come stock in this car? Im thing 3.23 but not sure.
Any other recomendations or advise from people who have improved their stock e.t using this programmer please let me know. As always thanks, your knowledge is greatly appreciated!!!
I am using one. I have the shift setting at 75%. That does not mean 75% firmer. It only means it is the third setting (50, 75, 100%, etc). I tried 50% and it is was a very mild change. 75% had a firmer shift. I got a small clunk in my rearend at 100%, so I left it at 75%. Its working great at 75%.
With stock cam/heads I do not think raising WOT shift points will help that much. There is not much point in increasing your RPM well above your power band. You peak power is in the mid 5k range.
Now if you could change your partial throttle shift points it would help improve drivability. Shame it only changes WOT shift points.
Thanks JA
