What EXTRA has to be done to tune a stroker?
Old Apr 11, 2006 | 12:19 AM
V-10 Killer's Avatar
Default What EXTRA has to be done to tune a stroker?
I'm hoping to have my 402 together in about 3 weeks, and then tuning starts all over again. Last year I used the "How to tune 101" writeup to tune the 231/237 in my motor for closed loop operation. This year I'll be doing the LS2 402 in an open loop tune. What do I have to do to the tune in addition to the normal tuning steps? Other than changing the cylinder volume cell, what else do I need to change for a safe "startup tune". I'm only planning on getting it drivable and get the VE tables dialed in. I'll be taking it to a pro for maximum power tuning.
Old Apr 11, 2006 | 05:00 AM
99whitews6's Avatar
If you tuned your old cam, you will be fine. Cylinder volume and IFR if you changed the injectors. I went from a stock head, LS6 intake, MS3 tune to a 408 with AFR 225s, decent size cam, 90/90 intake, and 42lb injectors and all I changed was the cylinder volume and IFR for the 42lbers and it started right up! Maybe bump up the cranking VE if it doesnt start first try.
